![]() | Home > Faults & Fixes > door wont open, |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 ![]() ![]() ![]() |
Had exactly this on my 06
doyleywood Member Since: 09 Feb 2018 Location: Rossendale lancashire Posts: 18 ![]() ![]() |
thanks for that, whats the price of a lock, did you fit it yourself? big job? thanks again |
Around £100
Thanks |
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
So got this issue but front passenger door won't open even with the manual key, so even if got a new lock how do I get the door open?
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 ![]() ![]() ![]() |
Had this on mine but on one of the rear doors, try pressing the unlock button on the dash above the radio it worked for me till I replaced the actuator switch. |
Mine wont open with the inside unlock burtton or handle in or outside; sounds like nothing moving in the door either, I've searched on here but not found anything of use to get the actual door open to even start the removal etc |
