Home > Faults & Fixes > door wont open,
doyleywood
door wont open,
probably been covered before but i'm new to the forum.
06 RRS sc , when opening car with remote key fob, front passenger door sometimes refuses to open, even trying to open the passenger door from inside via its own handle with the little black lock button still wont open, i have to remove the cover from the handle outside and use the key to open it. also the rear drivers side door refuses to lock unless you push in the little black button, but you have to do this every time someone exits via the door. thanks steve
Post #550777 Thu Mar 08 2018 12:27pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Had exactly this on my 06
New door lock from britparts stevenage and it’s all good now
Post #550800 Thu Mar 08 2018 4:40pm
doyleywood
thanks for that, whats the price of a lock, did you fit it yourself? big job? thanks again
Post #550932 Sat Mar 10 2018 4:31pm
Ezituper
Around £100
Took about 1 hr
Post #550941 Sat Mar 10 2018 5:47pm
doyleywood
Thanks
Post #551076 Sun Mar 11 2018 10:05pm
What's in the fridge?
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
So got this issue but front passenger door won't open even with the manual key, so even if got a new lock how do I get the door open?
Battery was on it's way out (now replaced with nice new one with 5 year guarantee!) just in case there is a cheeky reset that I'm missing that may magic it away Whistle
Thanks in advance Thumbs Up 2008 TDV8 Buckingham Blue- SOLD
Post #591860 Sat Dec 14 2019 12:44pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Had this on mine but on one of the rear doors, try pressing the unlock button on the dash above the radio it worked for me till I replaced the actuator switch.
Post #591862 Sat Dec 14 2019 1:19pm
Mine wont open with the inside unlock burtton or handle in or outside; sounds like nothing moving in the door either, I've searched on here but not found anything of use to get the actual door open to even start the removal etc Big Cry
Found this once the door is open...
https://www.rrsport.co.uk/forum/post463082.html 2008 TDV8 Buckingham Blue- SOLD
Post #592013 Wed Dec 18 2019 1:51pm
