Home > Technical > 2008 Range Rover Sport Diagnostic results
JimMcneil
2008 Range Rover Sport TDV8 HSE Java Black
Hi guys got my car put on a friends diagnostic machine.... it’s come up with the following codes. Can some of the forum with technical knowledge point me in the right direction please?
1 parking sensors.. B1B57-11 front sensor power circuit
2 parking sensor B1B58-11 rear parking sensor power circuit
3 lost communication with parking assist control module U0159-87
4 lost communication with ride level control module U0132-87
5 forward looking sensor C1A67-96
I don’t have park sensors working on my car. I also do not have cruise control working?
Any advice would be great. Thanks to all.
Regards jim
Post #550439 Sun Mar 04 2018 4:37pm
geoffsnook
Ignore the u codes for now you more than likely have a short to earth in the sensors try and unplug the front sensors first the plug is behind the front drivers headlight and then try it if the fault is still there try unplugging the rear sensors which is in the rear of the car on the passenger side i think Thumbs Up
Post #550441 Sun Mar 04 2018 5:02pm
geoffsnook
https://www.disco3.co.uk/forum/topic138487.html Thumbs Up
Post #550444 Sun Mar 04 2018 5:04pm
JimMcneil
Thanks very much, what’s your thoughts on the cruise control issue?
Regards jim
Post #550450 Sun Mar 04 2018 5:14pm
geoffsnook
Make sure your front acc is clean and clear sounds like it has something blocking what it can see Thumbs Up
Post #550452 Sun Mar 04 2018 5:38pm
JimMcneil
Hi the ACC is fully clear. Is it worth taking off the front bumper to check for broken wires to the ACC unit?
Post #550458 Sun Mar 04 2018 6:28pm
geoffsnook
i assume you have just got the car yes you can take the bumper off and make sure everything is connected up properly and no breaks in the wire but it will be worth spraying the screws at the bottom of the bumper as they tend to round off Thumbs Up
Post #550463 Sun Mar 04 2018 6:46pm
JimMcneil
Many thanks for the advice will keep this post updated once I get the bumper off the car...and when I check the parking sensors.
Very Happy
Post #550472 Sun Mar 04 2018 8:16pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I am adding to a situation , I have with the same fault . Ok have used GAP to identity that the rear sensors are all detected and the front otherwise.
Random , this, everything been fine for a year.
If I can do a con check on the front sensors I can assume that one of the sensors are at fault . But if all sensors according to GAP are not detected then there must be a power supply problem . Unless if the paths taken are in series, then it may cause all to fail.
My question is that , is there another power supply junction other than behind drivers headlight, that I can check.
Post #632441 Mon Apr 17 2023 9:24pm
