![]() | Home > Technical > 2008 Range Rover Sport Diagnostic results |
Ignore the u codes for now you more than likely have a short to earth in the sensors try and unplug the front sensors first the plug is behind the front drivers headlight and then try it if the fault is still there try unplugging the rear sensors which is in the rear of the car on the passenger side i think |
JimMcneil Member Since: 26 Aug 2012 Location: Scotland Posts: 13 ![]() ![]() |
Thanks very much, what’s your thoughts on the cruise control issue?
Make sure your front acc is clean and clear sounds like it has something blocking what it can see |
Hi the ACC is fully clear. Is it worth taking off the front bumper to check for broken wires to the ACC unit? |
i assume you have just got the car yes you can take the bumper off and make sure everything is connected up properly and no breaks in the wire but it will be worth spraying the screws at the bottom of the bumper as they tend to round off |
Many thanks for the advice will keep this post updated once I get the bumper off the car...and when I check the parking sensors.
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 211 ![]() ![]() ![]() |
I am adding to a situation , I have with the same fault . Ok have used GAP to identity that the rear sensors are all detected and the front otherwise.
