Home > Technical > Advice on cold start problem 2006 RRS 2.7
Deegan
Hi folks, I think the time has come for a new battery as when I first start it in the morning it fires up and cuts straight out, next time it will start but requires a light press of the throttle. But the more pressing issue is when it does start I'm greeted by a big plume of blue smoke,this only happens on the first cold start of the day, never any other times.
I have had the egr valve blanked,
Could this be in any way due to the low battery or possibly a much bigger problem?
It's a 2006 RRS 2.7tdv6
Post #549662 Sun Feb 25 2018 11:44am
Ch04oma
United Kingdom 2007 Range Rover Sport TDV6 HSE Siberian Silver
Sounds like glow plugs mate as myn does it. Your best getting a fbh kit as the glow plugs are a nightmare to get out if they do
Post #549834 Mon Feb 26 2018 11:21pm
adameverett
My car did exactly that, fire and stall. You can try 3 or 4 full cycles of the glow plugs before turning the key see if that helps. Wait for the light to go and repeat. My problem persisted and indy suggested fbh over glow plugs. Not a problem starting since. Just have to remember to warm the car 20mins before, yes it working round a fault but for the odd days we get cold snap I am happy.
Post #549842 Tue Feb 27 2018 7:59am
GodivaNige
No idea if the 2.7 is the same Adam, but with a TDV8, cycling the ignition is a pointless exercise. The glowplugs stay energized despite the light going out on the dash and remain on for a time even after the car has started.
The light on the dash is only an indication it’s ok to start the car but doesn’t mean the glowplugs have switched off at the same time the light goes out. Thumbs Up Whilst we have these very cold mornings, I’ve been counting to 5 after the light goes out before firing it up, all in the name of mechanical sympathy Very Happy
Post #549856 Tue Feb 27 2018 10:10am
Deegan
Excellent thanks to all of you for the replies.
I know I'm going to sound daft no but what is fbh that you refer to?
I'll get on the phone and order some glow plugs now
Post #549891 Tue Feb 27 2018 2:30pm
riverblanche
Hi,
get the heater plugs tested to see if/how many you need and a quote for changing them,
IF they break they can still be removed with out taking the head off, but depends if they have the tools and which one it is/position ISTR
As for FBH try the search button and wiki info when you have a few days doing nothing to have a read up Laughing
get the battery tested and if its on the way out get it changed, keep delaying it and managing your RRS will not appreciate and you may end up replacing the alternator as well
If its how you use the car get a charger for it plug in or solar search "Tim Solar"
and timed climate or a remote is great Thumbs Up you will read about them under the FBH Whistle
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #549896 Tue Feb 27 2018 2:52pm
Deegan
Thanks for that informative reply. I have a few days off so will read up on fbh thanks.
Also just going to bite the bullet and order a battery and glow plugs.
My mechanic can fit them as soon as they arrive, and I will dig out my trickle charger for these cold months
Post #549897 Tue Feb 27 2018 2:56pm
"FBH" is the fuel burning heater that helps the engine warm up in cold weather. It can be made to turn on early and start warming the coolant. This helps with cold starting as it warms the engine slightly.
Have the battery checked and have the alternator output checked too. 2012 SDV6 - it's missing a couple of cylinders
Post #550012 Wed Feb 28 2018 12:26pm
