Home > In Car Electronics > LED fault |
As you're soldering two components together it may be worth mounting them on a narrow plain board, that way the components will be protected from movement etc. you could then sleeve it in heat shrink and make it all tidy
Mon Feb 26 2018 4:35pm |
Geezer123 Member Since: 24 Feb 2018 Location: Cheshire Posts: 14 |
Very helpful. You could tell the manufacturer a thing or two. Many thanks. |
Mon Feb 26 2018 5:33pm |
Thanks, will give it a go. 👍🏻 |
Mon Feb 26 2018 7:04pm |
Hi all.
Sat Mar 10 2018 7:51pm |
The cap will have the pins marked as positive and negative, negative goes to the feed and positive faces the controller. The diode has a band on one side, so based on the drawing a posted earlier the end of the diode with a ring needs to face the cap. |
Sat Mar 10 2018 8:28pm |
That’s fantastic, really helpful. Many thanks.
Sat Mar 10 2018 8:42pm |
