Home > Technical > Electrical gremlins
DerrekL
Electrical gremlins
Hi,
Just recently when I begin a journey I can be a half mile or less into and the radio, heater fan switch off, the interior light comes on and my hazard lights keep flashing.
I can continue the journey but with hazards constantly flashing not such a great idea. If I do keep driving the car can go back to normal within 30 - 60 seconds whereby the radio comes back on, heater fan comes back on and things return to normality.
BUT, if I decide to try and park up and turn the car off then try to start it again when it is in the middle of its melt down then it fails to start at all.
Is there anything specific I should be checking? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #549077 Sun Feb 18 2018 7:05pm
HEFF
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
wow thats crazy hopefully someone will be able to help you out
when you have sorted this problem please post the answer
good luck.
ecu???
Post #549081 Sun Feb 18 2018 7:31pm
Ade99
United Kingdom 2008 Range Rover Sport TDV8 HSE Izmir Blue
Hi i had similar problem just before Christmas but I lost the power steering and the suspension dropped and loads of errors on the display ended up changing the hand break switch and the brake pedal switch I posted on here under Christmas Tree lights hope this helps
Post #549148 Mon Feb 19 2018 12:11pm
Disco_Mikey
CAN faults. Can be a bastard to track down when intermittent
Post #549195 Mon Feb 19 2018 7:20pm
DerrekL
Thanks guys for your opinions Thumbs Up Looks like I will be spending a good few hours trying to get to the bottom of this one then! RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #549286 Tue Feb 20 2018 2:37pm
DerrekL
I read this post recently:
http://www.rrsport.co.uk/forum/topic35912....p;start=30
...so I was going to check the air suspension control module over at the weekend. Any thoughts guys? Is this something you have replaced as a consequence of this sort of issue? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #554582 Thu Apr 19 2018 10:28am
DerrekL
Fault codes listed when plugged in to diagnostics and car not in 'hazards flashing doors locking' mode:
Ride level control module (2 faults) C1A20 - Permanent
C434 - Unknown fault code
Fault codes listed when plugged in to diagnostics and car is in 'hazards flashing doors locking' mode:
Instrument cluster control module (1 fault code) U0010 - Medium Speed CAN Communications Bus
TCM - Transmission control module (1 fault codes) and TCCM - Transfer case module control module (1 fault code) U0155 - CAN communication fault with IC
SASM - Steering angle sensor module (1 fault code) U0122 - Lost communication with vehicle dynamics control module
My thoughts about the above codes. When the car is not in crazy hazards flashing doors locking mode, it only shows the codes C1A20 and C434 are these two codes related to the air suspension compressor?
When the car is in crazy mode with hazards flashing doors locking, radio switching off etc; I am getting the TCCM faults. I did have all the plugs for the transmission ecu unplugged at some point, is this maybe a consequence of that, I may have to take the battery out and unplug/plugin all these TCCM connectors again ?
I believe the physical route goes like this:
TCCM (Transmission Control Module)-->CJB (Central Junction Box)-->Hevac (Heating panel-->Ipac (Instrument Panel)-->Radio?
So if the fault is fixed from the TCCM side it should in theory fix all the other fault codes? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #554820 Mon Apr 23 2018 10:25am
DerrekL
Replacement cluster fixed these issues Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #561683 Fri Jul 20 2018 11:16am
bratescubogdan@xnet.ro
Romania 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Vehicle fault - System Shutting Down
Hi DerrekL,
I have the same issue. Changing the instrument cluster solved the problem?
Post #563088 Sun Aug 12 2018 4:44pm
DerrekL
Indeed it did, once I replaced the instrument cluster all the annoying gremlins like doors locking, hazards on, radio switching off all stopped and was back to normal behaviour. Hope this helps. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #563167 Mon Aug 13 2018 10:34pm
