![]() | Home > Technical > Electrical gremlins |
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 ![]() ![]() ![]() |
wow thats crazy hopefully someone will be able to help you out
Ade99 Member Since: 28 May 2014 Location: wombourne Posts: 20 ![]() ![]() ![]() |
Hi i had similar problem just before Christmas but I lost the power steering and the suspension dropped and loads of errors on the display ended up changing the hand break switch and the brake pedal switch I posted on here under Christmas Tree lights hope this helps |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
CAN faults. Can be a bastard to track down when intermittent |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Thanks guys for your opinions |
I read this post recently:
Fault codes listed when plugged in to diagnostics and car not in 'hazards flashing doors locking' mode:
Replacement cluster fixed these issues |
bratescubogdan@xnet.ro Member Since: 12 Aug 2018 Location: Paulesti Posts: 1 ![]() ![]() ![]() |
Hi DerrekL,
Indeed it did, once I replaced the instrument cluster all the annoying gremlins like doors locking, hazards on, radio switching off all stopped and was back to normal behaviour. Hope this helps. |
