Home > Technical > Charging Battery and HDC indication |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1700 |
How old is the battery to start you may need a new one and you can either disconnect the battery or put a battery conditioner on it |
Fri Feb 09 2018 6:56pm |
Michael S Member Since: 20 Feb 2017 Location: West Norfolk Posts: 6 |
Thank you for your reply.
Fri Feb 09 2018 7:14pm |
You can leave the battery connected as once its charged as long as the charger/conditioner does what it says |
Fri Feb 09 2018 7:21pm |
I have the same warnings every time I start mine up....I assumed it`s normal as they go off. Steve. |
Fri Feb 09 2018 7:31pm |
Much appreciated both ! |
Fri Feb 09 2018 7:40pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I have a 2005 RRS petrol SC so different to yours and Steve's but I don't get any warning messages when I start the ignition. I get the usual lights come up at the beginning and a message saying "system check" and once that finishes I crank the engine and everything clears.
Fri Feb 09 2018 8:13pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
If you get HDC fault and special systems off, after starting then the battery is near the end of life / or requires charging. |
Fri Feb 09 2018 8:16pm |
Thank you both guys for your time , really good to know I keep an eye on the battery as it looks like these two issues are interconnected. |
Fri Feb 09 2018 8:23pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
I used to get the same warnings on every start, new battery, brake switch, bulbs... all the usual suspects replaced to no avail.
Fri Feb 09 2018 9:04pm |
Thank you GodivaNige , appreciated |
Sat Feb 10 2018 10:53am |
