![]() | Home > Technical > Charging Battery and HDC indication |
How old is the battery to start you may need a new one and you can either disconnect the battery or put a battery conditioner on it |
Michael S Member Since: 20 Feb 2017 Location: West Norfolk Posts: 6 ![]() ![]() ![]() |
Thank you for your reply.
You can leave the battery connected as once its charged as long as the charger/conditioner does what it says |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I have the same warnings every time I start mine up....I assumed it`s normal as they go off. Steve. |
Much appreciated both ! |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I have a 2005 RRS petrol SC so different to yours and Steve's but I don't get any warning messages when I start the ignition. I get the usual lights come up at the beginning and a message saying "system check" and once that finishes I crank the engine and everything clears.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
If you get HDC fault and special systems off, after starting then the battery is near the end of life / or requires charging. |
Thank you both guys for your time , really good to know |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
I used to get the same warnings on every start, new battery, brake switch, bulbs... all the usual suspects replaced to no avail.
Thank you GodivaNige , appreciated |
