Home > Technical > Heating vent output
TPS
Heating vent output
Hi all,
Today being rather cold and damp I noticed what seems to me like an issue with the cabin heating and wondered if this is a fault or just how they work.
The car warms up ok and cabin warms up. The side windows however were still misted up and not clearing. No problem I thought I would just adjust the vents on the sides of the dash to direct the air. I noticed that there was virtually no air coming from any of the vents. The unit was on auto with both sides set to 20 degrees. I switched to manual and turn the fan knob fully clockwise. Still no decernable flow of air. Pressing the demist button delivered a strong flow of air to the windscreen vents but nothing to the dash vents (as expected). The only way I could get any real flow of air from the dash vents was to turn the driver side temp control down to max cooling (this also set the passenger side to lowest setting). Switch back to auto 20 degrees and again no air flow.
I have also noticed that when using the timed or remote heating (FBH) the cabin windows don’t really de-ice and the fan does not speed up to blow the hot air into the cabin and window demist vents.
So is this normal or do I have a fault with the heating control unit causing it not to control the fan correctly?
Appreciate any experience Andy advice. -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #546424 Sun Jan 21 2018 1:16pm
Aren't there some buttons to say where you want the air to come out ?
footwell, vents, windscreen
Post #546426 Sun Jan 21 2018 1:27pm
TPS
Yes there are direction buttons but issue was more that the fan was not switching to a high speed setting. Unless I set temp to max cooling. -----------------------------------------------
Post #546428 Sun Jan 21 2018 1:33pm
GodivaNige
Clogged pollen filter?
Post #546430 Sun Jan 21 2018 2:40pm
TPS
Yes worth a check.
Would a clogged pollen filter stop the fan running at higher speeds? -----------------------------------------------
Post #546431 Sun Jan 21 2018 2:43pm
GodivaNige
When in Auto, the fan may not run at high speed if the cabin temp is close to setpoint. If you can manually increase the fan speed without a problem then I’d say it was fine. A blocked pollen filter will restrict airflow from the vents as all delivered air goes through this filter.
To check, try removing the filter and check if there’s a dramatic increase in air from the vents, though, when you remove it, it will be obvious if it is clogged. These filters are specified to be changed at every service for a reason, they need it as they become blocked quite quickly with dust.
Post #546432 Sun Jan 21 2018 2:50pm
Tyrefitter
That’s interesting as mine doesn’t seem to blow half as much as my other RRS2 did but didn’t think of pollen filter,I’ll check mine this week,when mines on full power it hardly sends any heat out.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #546433 Sun Jan 21 2018 2:56pm
GodivaNige
Just in case anyone is thinking about it, don’t be tempted to remove the pollen filter permanently. If you do, dust will collect on the fan impellers reducing its efficiency and will also eventually clog the air passages in the heat exchanger and evaporator which will result in them having to be removed and cleaned.
For the cost of the filters and the ease in which they can be replaced, it’s worth changing them out regularly. Doesn’t hurt to swap them every six months. The carbon coated ones will also remove odours, so worth paying a little more for these over the non coated cheaper versions.
Post #546434 Sun Jan 21 2018 3:20pm
If its blowing hard on defrost it doesn't sound like the filter, but easy to check
Post #546435 Sun Jan 21 2018 3:24pm
GodivaNige
It’s worth checking Andy because what can happen when the fan is running at max with a blocked filter, the suction can be enough to deform the filter allowing unfiltered air to pass. When the fan speed is lowered, the filter regains it’s shape in the housing Thumbs Up
Post #546436 Sun Jan 21 2018 3:29pm
Tyrefitter
Some info here about changing it on the RRS2
http://www.roverparts.com/resources/videos...port-2014/
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #546438 Sun Jan 21 2018 3:43pm
Cymruambyth
Wales
Is it the same for older ones like mine? Steve.
Post #546439 Sun Jan 21 2018 4:29pm
older ones, you open the glovebox.
pull the side supports out (to access fusebox)
and there is a small letterbox that the filter slides into at the top
Post #546441 Sun Jan 21 2018 5:09pm
Cymruambyth
Wales
Cheers Andy Thumbs Up Steve.
Post #546442 Sun Jan 21 2018 5:12pm
TPS
Here is a link for the RRS 1 procedure.
I will check mine when the rain / snow stops.
Post #546443 Sun Jan 21 2018 5:17pm
