![]() | Home > Technical > Sat Nav not working properly! |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Highly likely to be a faulty GPS antenna in the roof mounted sharks fin. Very common fault
Tricky Micky Member Since: 22 Jan 2018 Location: Chester Posts: 9 ![]() ![]() ![]() |
dam , wish i had joined last week just bought a second hand one from a breaker , fitting it this week some time , but i have printed off the fix just in case that one breaks down as well , great tip thank you |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Be sure to apply a liberal amount of silicone between the shark fin and body of the car. I didn't and the rear pillars got wet. inside. Otherwise it's a very simple job. 2019 RRS P400e Autobiography
thanks for the tip , was in my mind to do something like this but always good be be prompted |
I didn't apply any silicon and have had no leaks. All I did was give the seal on the sharks fin a really good clean and then cleaned & polished the roof where it mounts. Torqued the two nuts up nice and tight and it's been ok. |
Hmm. I tightened the bolts up pretty tight. Maybe not enough? 2019 RRS P400e Autobiography
