Home > Technical > Sat Nav not working properly! |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Highly likely to be a faulty GPS antenna in the roof mounted sharks fin. Very common fault
Thu Jan 11 2018 5:00pm |
Tricky Micky Member Since: 22 Jan 2018 Location: Chester Posts: 9 |
dam , wish i had joined last week just bought a second hand one from a breaker , fitting it this week some time , but i have printed off the fix just in case that one breaks down as well , great tip thank you |
Mon Jan 22 2018 3:00pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
Be sure to apply a liberal amount of silicone between the shark fin and body of the car. I didn't and the rear pillars got wet. inside. Otherwise it's a very simple job. 2019 RRS P400e Autobiography
Mon Jan 22 2018 4:21pm |
thanks for the tip , was in my mind to do something like this but always good be be prompted |
Wed Jan 24 2018 3:19pm |
I didn't apply any silicon and have had no leaks. All I did was give the seal on the sharks fin a really good clean and then cleaned & polished the roof where it mounts. Torqued the two nuts up nice and tight and it's been ok. |
Wed Jan 24 2018 3:35pm |
Hmm. I tightened the bolts up pretty tight. Maybe not enough? 2019 RRS P400e Autobiography
Thu Jan 25 2018 5:08pm |
