![]() | Home > In Car Electronics > 12v boot socket. |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
It isnโt normally live unless someone before you has taken out the relay in the glove box and used a jumper wire |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
How long would it stay live after shutting down then? Maybe there`s a timer (on my ST if was about 30 mins). Steve. |
I`m hoping it`s live as that`s the only way I can work out how to attach my ctek charger! Steve. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
It turns off as soon as you turn the ignition key to 0
Mine must be bypassed then |
it doesn't matter that you don't have towbar electrics, if going behind the trim.
