Home > In Car Electronics > 12v boot socket.
Cymruambyth
Wales
12v boot socket.
I assume the rear 12v socket is a permanent live. I`ve just plugged my sat nav in, locked car and waited almost 30 mins and it was still on. Is this right? Steve.
Post #545182 Mon Jan 08 2018 2:53pm
Buckster
It isnโ€™t normally live unless someone before you has taken out the relay in the glove box and used a jumper wire Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ€ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐Ÿ˜Ž
Post #545201 Mon Jan 08 2018 5:34pm
Cymruambyth
Wales
How long would it stay live after shutting down then? Maybe there`s a timer (on my ST if was about 30 mins). Steve.
Post #545202 Mon Jan 08 2018 5:36pm
Cymruambyth
Wales
I`m hoping it`s live as that`s the only way I can work out how to attach my ctek charger! Steve.
Post #545203 Mon Jan 08 2018 5:36pm
It turns off as soon as you turn the ignition key to 0
Yours could be bypassed?
or pull that trim away and connect it to the towbar plugs lower down.
There is a thick green wire with brown stripe that is +12v. (not to be cinfused with the reversing light wire)
Connect CTEK black to a metal bolt behind there.
Post #545208 Mon Jan 08 2018 5:59pm
Cymruambyth
Wales
Mine must be bypassed then Thumbs Up I don`t have towbar electrics Crying or Very sad Steve.
Post #545209 Mon Jan 08 2018 6:03pm
it doesn't matter that you don't have towbar electrics, if going behind the trim.
Anyway if your sockets, bypassed, that's fine.
As long at the socket stays plugged in and your are happy to pay the money for the adaptor lead
Post #545211 Mon Jan 08 2018 6:07pm
