Home > Technical > RESTRICTED PERFORMANCE - CHECKS UNDERTAKEN SO FAR
DSJ
red triangle came on when i accelerated fast from the junction with engine management light, can hear whistling noise from drivers side vent when foot is off pedal
have done the following so far:
checked inlet manifold x 2 for cracks, no visual signs and no soot found under the engine cover
cleaned MAF sensor x 2, found oil in MAF sensor housing
checked air filter - 80% full of oil
cleaned MAP sensor
checked inlet hoses
checked inter cooler hose near front wheel
checked turbo actuator arm under wheel arch
checked actuator on CSOV under wheel arch
fault codes as below:
P1247 - DTC definitions NOT found - refer to manual
P006A - MAP mass or volume air flow correlation
P0235 - Turbocharger/Supercharger Boost Sensor A Circuit
Is there any other checks to be performed?
Post #544840 Thu Jan 04 2018 9:42pm
Bodsy
Site Sponsor
Have you had a look at the maf /.map live values to make sure it’s working? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #544851 Fri Jan 05 2018 12:37am
Disco_Mikey
IN what way have you checked the crossover valve?
Post #544856 Fri Jan 05 2018 7:05am
