![]() | Home > Technical > Rrs Tdv8 hdc fault |
Pedro8808 Member Since: 16 Oct 2016 Location: Glasgow Posts: 5 ![]() ![]() ![]() |
Also would a k&n panel filter cause any issues |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Most likely a blocked fuel filter, but an excessively oily K&N is known to affect the MAF sensors
It's going to be booked in for a service in January I'll make sure it's included thanks for the reply it was serviced by the place i bought it from but im guessing it was oil and filter only |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 ![]() ![]() ![]() |
A split intercooler hose can cause this and the usually go on the bottom of the hose where you can’t see it Clickadeeclick |
Definitely worth a check |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 320 ![]() ![]() ![]() |
Mine did that the other day, came up with a fault code for brake light switch. I bought it a new switch, put it in the glove box, and it's been fine since |
Was it during acceleration d9 or just whilst braking |
It was during acceleration/cruise I think, will check with the missus when she wakes up. |
