Home > Technical > Rrs Tdv8 hdc fault
Pedro8808
United Kingdom 2009 Range Rover Sport TDV8 HSE Lugano Teal
Rrs Tdv8 hdc fault
Hello everyone I've owned my sport a year now 09 tdv8 I've noticed a fault that only occurs on harder acceleration ie foot to the floor stuff
The lights of doom appear hdc fault-park brake fault-suspension lowering
If i pull over and turn it off start back up no faults present suspension shoots right back up
The sport was serviced when i bought it 6.5k miles ago but I'll take that with a pinch of salt normal acceleration is fine mild acceleration is fine only hard acceleration causes the fault has anyone experienced anything similar it doesnt appear when i press brake pedal and all bulbs appear to function ok
I have noticed that the revs hold around 3k before it throws up the fault
Post #544466 Sun Dec 31 2017 6:18pm
Pedro8808
Also would a k&n panel filter cause any issues
Post #544471 Sun Dec 31 2017 7:17pm
Disco_Mikey
Most likely a blocked fuel filter, but an excessively oily K&N is known to affect the MAF sensors
Whatever happens, it needs plugged in
Post #544472 Sun Dec 31 2017 7:46pm
Pedro8808
It's going to be booked in for a service in January I'll make sure it's included thanks for the reply it was serviced by the place i bought it from but im guessing it was oil and filter only
Post #544475 Sun Dec 31 2017 7:54pm
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
A split intercooler hose can cause this and the usually go on the bottom of the hose where you can’t see it Clickadeeclick
Post #544481 Sun Dec 31 2017 8:57pm
Pedro8808
Definitely worth a check
Post #544482 Sun Dec 31 2017 9:08pm
d-9
Mine did that the other day, came up with a fault code for brake light switch. I bought it a new switch, put it in the glove box, and it's been fine since Smile
Post #544492 Sun Dec 31 2017 11:58pm
Pedro8808
Was it during acceleration d9 or just whilst braking
Post #544493 Mon Jan 01 2018 12:20am
d-9
It was during acceleration/cruise I think, will check with the missus when she wakes up.
Post #544498 Mon Jan 01 2018 10:12am
