Home > General > Thumping sound when turning
M12UPY
England 2009 Range Rover Sport TDV6 HSE Lux Stornoway Grey
Ok I'm getting a thumping sound almost like a flat tyre when turning more so to the left i checked tyre pressure and all good then I check tread and there is 1mm difference would this cause the noise also the car pulls to the left quite a bit so need realigning! Is it the tracking, tyres or bearing please not the diff 🙈
Post #544188 Wed Dec 27 2017 9:19pm
Father Jack
Very hard to tell as the cause could be many things. I had what sounded like the same sort of issue as you did recently, noticeable low rumbling when a little left hand turn on, at 30mph up. Almost sounded like a washing machine drum spinning down (so thump and rumble). Turned out to be a bearing and these cars are well known for eating bearings, probably a combination of vehicle weight, driver style and LR skimping on spec. Changed bearing and noise gone. Saw the old one and it was completely shot.
Take it to an indy as I did mine, we did a 15 min test drive and put it on the ramp and job done.
Post #544563 Tue Jan 02 2018 8:54am
Disco_Mikey
Most likely a wheel bearing
Potentially a worn suspension arm, or ball joint someplace. A decent garage should be able to find the issue within a few minutes of road test/investigation Thumbs Up
Post #544568 Tue Jan 02 2018 10:49am
shug89
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
After having the control arm bushes replaced on mine, and a 4 wheel alignment, a new noise manifested itself when turning. A distinct clunk when turning slowly only when moving, when stationary the noise would never appear.
I greased the lock stops and that did nothing, then liberally applied some WD40 to the lower steering UJ and it's been silent ever since. Worth a try i'd say Smile
Post #544586 Tue Jan 02 2018 2:16pm
M12UPY
Arrrrrrraaahhhhhhh! Just replaced bearing And it's still there sounds like rubbing when going straight and worse when turning left but not when turning right
Post #546781 Thu Jan 25 2018 9:34pm
