![]() | Home > General > Thumping sound when turning |
Very hard to tell as the cause could be many things. I had what sounded like the same sort of issue as you did recently, noticeable low rumbling when a little left hand turn on, at 30mph up. Almost sounded like a washing machine drum spinning down (so thump and rumble). Turned out to be a bearing and these cars are well known for eating bearings, probably a combination of vehicle weight, driver style and LR skimping on spec. Changed bearing and noise gone. Saw the old one and it was completely shot.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Most likely a wheel bearing
shug89 Member Since: 30 Nov 2017 Location: Lancashire Posts: 7 ![]() ![]() ![]() |
After having the control arm bushes replaced on mine, and a 4 wheel alignment, a new noise manifested itself when turning. A distinct clunk when turning slowly only when moving, when stationary the noise would never appear.
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 ![]() ![]() ![]() |
Arrrrrrraaahhhhhhh! Just replaced bearing And it's still there sounds like rubbing when going straight and worse when turning left but not when turning right |
