Home > Technical > headlight adjustment on rrs 2007
raysheppard1954
hi , ive recently brought my 2007 range rover sport and Ive noticed the headlights on dipped beam are low,i thought they might adjust on there own or there is a switch to higher them.is there away to do this ,ive replaced the n/s headlight recently ,any advise would be good,thanks ray.
Post #544049 Tue Dec 26 2017 8:41am
geoffsnook
if its a HSE it should have xenon headlights which should self level if you have replaced one recently you may need to get a garage to adjust them to the correct height i believe Thumbs Up
Post #544053 Tue Dec 26 2017 9:24am
Easy enough to adjust, the two small hexagon drives one each end shown in picture, can't actually remember which one is left to right and which is up and down, could try shinning them against a wall to level them up a bit initially. Does self levelling not just level the headlights in relation to the angle etc. of the vehicle, it doesn't actual adjust the headlamp alignment setting.?
Post #544054 Tue Dec 26 2017 9:48am
nothing automatic about them AFAIK.
Think it just relies on the air suspension keeping the car level, so no electric leveling required
Post #544055 Tue Dec 26 2017 9:56am
According to the build spec. on mine it has adaptive and automatic levelling headlights, although it is a MY13 car if that makes a difference.
Post #544057 Tue Dec 26 2017 10:11am
Col is correct. You use the two adjusters visible in his picture. I usually park opposite a wall or, ideally, on the side of a straight, quiet lane. Use the adjusters to get the beam pattern as required.
Correctly adjusted lights make a huge difference to night driving. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #544070 Tue Dec 26 2017 2:40pm
Eaters
Re: headlight adjustment on rrs 2007
When you say low, do you mean just a bit low or are they pointing almost directly down. If the latter then this is more serious with adaptive headlights. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #544091 Tue Dec 26 2017 8:49pm
Eaters
See here
http://www.rrsport.co.uk/forum/topic45088.html Robin
Gone:
MGZTT 190 2.5
Post #544092 Tue Dec 26 2017 8:51pm
