![]() | Home > Technical > headlight adjustment on rrs 2007 |
raysheppard1954 Member Since: 21 Sep 2017 Location: birmingham Posts: 10 ![]() ![]() ![]() |
hi , ive recently brought my 2007 range rover sport and Ive noticed the headlights on dipped beam are low,i thought they might adjust on there own or there is a switch to higher them.is there away to do this ,ive replaced the n/s headlight recently ,any advise would be good,thanks ray. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Easy enough to adjust, the two small hexagon drives one each end shown in picture, can't actually remember which one is left to right and which is up and down, could try shinning them against a wall to level them up a bit initially. Does self levelling not just level the headlights in relation to the angle etc. of the vehicle, it doesn't actual adjust the headlamp alignment setting.?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
nothing automatic about them AFAIK.
According to the build spec. on mine it has adaptive and automatic levelling headlights, although it is a MY13 car if that makes a difference.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
Col is correct. You use the two adjusters visible in his picture. I usually park opposite a wall or, ideally, on the side of a straight, quiet lane. Use the adjusters to get the beam pattern as required.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
When you say low, do you mean just a bit low or are they pointing almost directly down. If the latter then this is more serious with adaptive headlights. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
See here
