![]() | Home > Wheels & Tyres > 2010 TDV8 Autobiography TPMS part numbers |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
The one's fitted on mine are the LR070840 the LR086928 is for the pre-facelift 05-09 RRS1. Although the TPMS system on a RRS1 is pretty much a waste of time, they are about £60.00 each from a dealer but I did manage to get a set of four genuine ones off fleabay for £80.00, if you do replace them although the car should automatically recognise them, I would suggest you make a note of the serial number of each sensor and which position the wheel is in on the car so if you do have a issue you can tell the system manually which position the sensor is in, I believe the only sensor it will not recognise automatically is if there is one fitted to the spare wheel.
eyespider Member Since: 09 Oct 2016 Location: Oxford Posts: 15 ![]() ![]() ![]() |
Thanks for the advice Col, will see if I can get some |
