Home > Wheels & Tyres > 2010 TDV8 Autobiography TPMS part numbers
eyespider
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Java Black
Hi all
I purchased a set of genuine alloys to use as a winter set. However they came with standard valves and not the TPMS ones. I'd like to get a set of valves for the new alloys.
I was just wondering without taking the tyre off my old alloys (which are the same size tyre 20inch with 275/40/20)
is there any other way of finding the correct part number.
I emailed a dealer but they could only tell me there were two part numbers LR086928 or LR070840
Anyone know which one with would be
regards
Post #542700 Tue Dec 05 2017 2:40pm
The one's fitted on mine are the LR070840 the LR086928 is for the pre-facelift 05-09 RRS1. Although the TPMS system on a RRS1 is pretty much a waste of time, they are about £60.00 each from a dealer but I did manage to get a set of four genuine ones off fleabay for £80.00, if you do replace them although the car should automatically recognise them, I would suggest you make a note of the serial number of each sensor and which position the wheel is in on the car so if you do have a issue you can tell the system manually which position the sensor is in, I believe the only sensor it will not recognise automatically is if there is one fitted to the spare wheel.
Post #542735 Tue Dec 05 2017 7:47pm
eyespider
Thanks for the advice Col, will see if I can get some
Post #542774 Wed Dec 06 2017 3:08pm
