Home > Faults & Fixes > Tdv8 fault code suspension and gearbox fault
Davidtdv8
2008 tdv8 hat Was fine and driving fine this morning then went to go out this afternoon and dash lit up like a Christmas tree so scanned with snap on solus and got codes
U0416
U0403
U0421
Been told battery, brake light switch but battery’s only 6 months old
I also think I have a problem with the Rear diff motor now and again
Dose any one know what it could possibly be before it goes in to dealer
Post #541905 Sun Nov 26 2017 10:10pm
Eaters
Just had some issues with mine. Flat battery turned out to be a duff alternator. So a brand new battery went flat in a short whil.
I suggest you check your battery voltage checked and also check for a good charge from the alternator. Both easy tests (Green Flag did mine) to eliminate those issues as the symptoms you describe mirror what I had although I can’t speak for the codes you mention.
See here for more info
http://www.rrsport.co.uk/forum/topic49170.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #541910 Sun Nov 26 2017 10:47pm
Davidtdv8
A will get my optimiser on the battery today and see if that works cheers
Post #541916 Mon Nov 27 2017 8:00am
Disco_Mikey
You need the fault codes from all the modules Thumbs Up
Post #541918 Mon Nov 27 2017 8:29am
Davidtdv8
Tdv8
Been in to local Range Rover Indy and it’s something to do with the Rear e diff motor or diff mechanism will post more when repaired
Post #542775 Wed Dec 06 2017 3:09pm
Hocks172
Ive had to change the actuator on my e-diff, so could be that? does it grind every now and again? RRS Autobiography SDV6 19
Tesla model 3 long range SOLD!
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #542798 Wed Dec 06 2017 7:12pm
Davidtdv8
Ye was grinding now and again but then put all sorts of light on dash but had motor changed and all good again now
Post #542799 Wed Dec 06 2017 7:13pm
Hocks172
Thumbs Up RRS Autobiography SDV6 19
RRS HST Sold!
Post #542802 Wed Dec 06 2017 7:31pm
ShooterNeil
Do all TDV8s have the e-diff 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #542805 Wed Dec 06 2017 7:57pm
Davidtdv8
A don’t think so mines the tdv8 hst and has e diff don’t know how to tell
Post #542806 Wed Dec 06 2017 7:58pm
GodivaNige
No, there’s no e diff on my car
Post #542807 Wed Dec 06 2017 8:07pm
Most TDV8s don't have the e-diff. Indeed, I would say less than 1% of all RRS1 have e-diff. It's as rare as a rare thing. 2012 SDV6 - it's missing a couple of cylinders
Post #542812 Wed Dec 06 2017 8:41pm
I think it was only the HST that had the e-diff standard, otherwise it was a paid option. Without getting under the car to look is there anything on the 4x4 screen on the HST version to indicate it might be fitted ?..
Post #542815 Wed Dec 06 2017 8:47pm
Davidtdv8
From what a was seen if you turn the rotary nob in center to far right position mud ruts a think on screen in 4x4 screen it comes up with a padlock on the pic of the Rear diff
Post #542817 Wed Dec 06 2017 8:53pm
ShooterNeil
Mine shows that on rock crawl center to locks 61 AB 5.0 supercharged rocket
Post #542820 Wed Dec 06 2017 9:23pm
