Home > Faults & Fixes > Tdv8 fault code suspension and gearbox fault
You can get the centre diff to lock by selecting rock crawl (far right on Terrain Response). Not sure if the rear will also lock by selecting rock crawl but I guess it will. The alternative is to look at the rear diff through the left rear wheel arch. Lift to off road height and look for wires going to a motor on the diff. Wires/motor means e-diff. No wires/motor means open diff. Don't confuse with the EPB module which is above the rear diff and is a rectangular black box. 2012 SDV6 - it's missing a couple of cylinders
Post #542825 Wed Dec 06 2017 9:53pm
Davidtdv8
Am not at home at min but when a get home will take a picture of screen
Post #542835 Thu Dec 07 2017 5:03am
Camelrock
The e-diff was fitted to the factory HST's and the G4's as standard every other fitted e-diff was an optional extra 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #543661 Mon Dec 18 2017 1:10pm
