Home > For Sale & Wanted > [SOLD] VPLSS0140HFX - GENUINE LAND ROVER ILLUMINATED SIL |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Hi Buckster
Sat Nov 11 2017 8:51pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Devon, unfortunately that part Number comes up for 2010-2013 models only, in answer to your question.
Sat Nov 11 2017 9:14pm |
Even though the part number is for 2010 to 2013 I would say they would fit. Comparing the appearance of the trims of a 2006 there doesn't appear to be any difference. The loom just plugs into the kick panel trim in the footwell taking a split from the floor or door lighting.
Sat Nov 11 2017 9:42pm |
in that case if Col or anybody else confirms they fit , I'll take them
Sat Nov 11 2017 9:56pm |
No worries, hopefully Col will be able to say as the resident part guru 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Nov 11 2017 10:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5010 |
I can't tell you for certain they will fit, however I can tell you the part number for standard pre-facelift one's has changed to the same as the 2010 - 2013 facelift variant so on that basis I see no reason why they wouldn't fit. If you completely remove your existing one's first, I would suggest you buy a few spare retaining clips (IPN500090) as these tend to distort or disappear inside the bodywork although it is quite possible the new trims Buckster has may already have new one's fitted.
Sat Nov 11 2017 10:21pm |
Cheers Col
Sun Nov 12 2017 6:05pm |
Thanks for the info Col, your parts knowledge is epic as always hope life is treating you well out there?
Sun Nov 12 2017 7:15pm |
All good here Buddy, best move I ever made (pun intended) Can't believe it's over a year already.
Mon Nov 13 2017 1:20am |
Devon you have a PM 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Nov 25 2017 10:37pm |
P.M belatedly replied |
Thu Dec 07 2017 8:12pm |
You have a PM Devon 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Dec 26 2017 9:29pm |
Pm replied |
Tue Dec 26 2017 10:22pm |
You have a PM Devon, 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Jan 04 2018 10:45am |
