![]() | Home > Technical > Parking Sensors |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5019 ![]() ![]() ![]() |
how does it tell you the parking sensors aren't working?
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 ![]() ![]() ![]() |
if you have an IIDTool, it will tell you what is wrong.
We wont be able to help unless the op puts on what is wrong as Andy k says as you have separate issues here with the cruise it could be the switch or the wiring behind the air bag which is a common problem the parking sensors can be a lot of different things such as a sensor/wiring/switch/modual so if you give us some more info i'm sure someone will be able to help |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 ![]() ![]() ![]() |
Well, problem solved...sort of!
