Home > Technical > Parking Sensors |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
how does it tell you the parking sensors aren't working?
Sat Oct 07 2017 4:43pm |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 |
if you have an IIDTool, it will tell you what is wrong.
Sat Oct 07 2017 7:32pm |
We wont be able to help unless the op puts on what is wrong as Andy k says as you have separate issues here with the cruise it could be the switch or the wiring behind the air bag which is a common problem the parking sensors can be a lot of different things such as a sensor/wiring/switch/modual so if you give us some more info i'm sure someone will be able to help |
Sun Oct 08 2017 10:05am |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 |
Well, problem solved...sort of!
Tue Oct 10 2017 7:13pm |
