Home > General > Plug in hybrid?. No! charger connected through tow bar elect
shepp
Hello all
As prep for winter. Bought a new charger, currently have a Absaar start and charge. It's like using a sledge hammer to break a wallnut, and ring 4 amp intelicharge which is not powerful enough. So bought a new toy.
A CTEK MXS 10, 2.5meter extension and tow bar adaptor.
So easy to charge the battery, no need to lift the bonnet. The Ctek chargers have great reputation for extending the life of all sorts of batteries.
 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #536770 Sat Sep 30 2017 1:11pm
DrRob
I've got a similar set up. Only use it if car has been stood for a while. Works a treat though Thumbs Up Visitor from fullfatrr.com
Post #536775 Sat Sep 30 2017 2:51pm
Cymruambyth
Wales
I have a similar model...great for conditioning the battery once a year. Not sure if I could use it on the Sport though. Sure I read I`d need a better spec one! Steve.
Post #536776 Sat Sep 30 2017 3:02pm
shepp
I've got mine for over winter. The wife only travels 6 miles a day, three days a week. Using the remote pre heat twice a day will definitely give the battery a battering.
10 amp charger not big enough for you're sport Steve, what battery have you got!!?? Shocked MY12 RRS HSE
Gone 90
Gone s2000
Post #536785 Sat Sep 30 2017 4:57pm
Cymruambyth
Wales
I`m not sure which Ctek I have...I think it`s a smaller version than the one in the pic. Not much use anyway as the Sport doesn`t fit in my garage Crying or Very sad Steve.
Post #536786 Sat Sep 30 2017 5:12pm
My 4A one works fine.
I put in the the boot with a mains extension lead coming out.
Post #536789 Sat Sep 30 2017 5:32pm
shepp
I have way to many important things in my garage to put the car in it (or maybe tat) that's why I got the extension and tow bar plug. Just back the sport up to the garage and plug it in. Charger stays fixed to wall in the garage while the lead feeds under the door.
4amp Ctek is perfectly acceptable, just takes a little longer, but the so called intelligent Ring one I have, keeps dropping to 2amp after 10 minutes. It never fully charged the battery. MY12 RRS HSE
Gone 90
Gone s2000
Post #536791 Sat Sep 30 2017 6:14pm
That's an interesting way of doing it.
Did you buy their garage bracket ?
Post #536792 Sat Sep 30 2017 6:23pm
shepp
Currently got a make shift bracket, while I determine which is the most suitable bracket as there is a choice of 2. MY12 RRS HSE
Gone 90
Gone s2000
Post #536806 Sat Sep 30 2017 10:36pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Shepp, in the pic on your first post the charger is set to Normal charge mode, but is it not an AGM battery fitted? Would it be better charging on the AGM mode?
 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #536808 Sun Oct 01 2017 3:49am
shepp
It has a Varta silver 020 fitted, not an AGM.
It was swapped before I got the vehicle.
I looked into it and there are pros and cons to either battery. Apparently the AGM ones will last longer if looked after properly, but that is the case with all batteries.
I have not suffered any strange side affects, that sometimes happen if not using a Landrover branded battery. MY12 RRS HSE
Gone 90
Gone s2000
Post #536813 Sun Oct 01 2017 7:53am
That is interesting, I couldn't physically fit a 020 battery into my car as there was insufficient room with out modifying the battery tray and moving the wiring and leads. Possible being a 5.0 s/c it's different under the bonnet I suppose, would be nice if you wouldn't mind positing a picture so could have a look.
Post #536821 Sun Oct 01 2017 9:30am
Cymruambyth
Wales
If I back up to my garage on my narrow drive,,,I can`t get out Laughing Steve.
Post #536876 Sun Oct 01 2017 8:55pm
muddywheels
Milk Float Man
I used mx 5.0 on both my RRS and DS without issues Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #536883 Sun Oct 01 2017 9:20pm
Cymruambyth
Wales
Ahhh, that`s what mine is...5.0 Thumbs Up Steve.
Post #536886 Sun Oct 01 2017 9:33pm
