![]() | Home > In Car Electronics > Subwoofer rattle |
NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36 ![]() ![]() |
I have the HK sound system in my 2011 Sport.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Have a vauge recollection there have been previous posts on this issue, may have even been a L/R service bulletin on it. Can't really remember fully but a search might turn something up.
I have done a search but nothing useful.
As I said only had a vague recollection, so could be getting totally muddled up with something else. If there is a bulletin of any sort should be on Topix somewhere. I assume all the panel retaining clips are there none broken or missing.
No. All ok. Think it is a design issue. Will just turn the sub volume down ! |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
I had the same issue of vibration and rattle but both are relatively easy to fix and I have put a post in tips and tricks to explain. |
