Home > Technical > Electronic Park Brake issue.
Page 1 of 3 123>
Cymruambyth
Wales
Ok, so this is my first fault. Applied the brake yesterday when I got the car home and it was fine.....even held in neutral on my drive which has a slight slope, impressed. Got home from work this morning, applied it and it made an awful squealing noise with message, park brake inoperable...or something similar.
Tried again not long ago and it was fine.
I googled it and read it may be that the shoes need adjusting. The guy I bought it from said it may also be the fact it hasn`t been used in the 4 months since he`s had it.
He has said if it happens again then I should find a local specialist and he`ll sort me out, which is good.
Could it be that they sometimes don`t get used very often? Steve.
Post #535474 Fri Sep 15 2017 4:53pm
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Don't no if this will help but hope so, me and the wife went away on holiday for two weeks came back to the long stay car park started the car pressed release on the handbrake and reversed only to hear a crunch and grinding noise. Drove it home booked it into the local LR dealership mechanic said they had ceased on in the two weeks away and advised us to leave the hand brake off if it was to be left for any length of time. Then came there bill £600 Big Cry hope you hav'nt got the same problem Bow down
Post #535477 Fri Sep 15 2017 5:23pm
Cymruambyth
Wales
Ah right. I don`t think it`s siezed as it worked just now. I had similar on my Scooby when I`d washed the car and then it froze over night.....shredded the ABS rings Laughing That was costly. Steve.
Post #535478 Fri Sep 15 2017 5:26pm
Johnski
How can you leave the handbrake off, it comes on automatically when ignition is turned off and you leave it in Park, which if you don't put it into Park, it also returns whatever position it was in back to Park? Whistle
I am of course talking about electronic handbrake which is fitted to most models. Wink John
Post #535481 Fri Sep 15 2017 5:48pm
Cymruambyth
Wales
Mine doesn`t do that nor my mates 3.6 HSE. Steve.
Post #535482 Fri Sep 15 2017 5:49pm
Johnski
Sorry, Does it not have electronic hand brake system? Just checked my handbook and it also states in there this is a normal procedure. John
Post #535483 Fri Sep 15 2017 5:51pm
Cymruambyth
Wales
Yes mate, it`s electronic. Maybe that`s a feature on newer ones.....mine is 2006. Steve.
Post #535485 Fri Sep 15 2017 5:52pm
Johnski
Info from facelift manual MY12 and actually seen when getting back into car, and the gear change dial you actually see move to Park. Not doubting you at all, it could be a later introduction, if so I'm sorry not knowing about the earlier models. Embarassed
Also if you leave handbrake on when trying to drive away it turns it off/releases it. John
Post #535486 Fri Sep 15 2017 5:54pm
DrRob
Sounds like it needs adjusting.
Refer to Bodsys Brake Bible on Disco3 forum http://www.disco4.com/wiki/Maintenance or even better still have Bodsy come and look at it for you at the expense of the seller Thumbs Up
He's one of the mobile mechanics that are LR gurus and site sponsors. He's the closest to you being based out of Telford.
I'd be pushing that option Thumbs Up
And then use it every time you park up to avoid future issues as it's an MOT test item. Plus have it cleaned and adjusted every annual service Visitor from fullfatrr.com
Post #535487 Fri Sep 15 2017 5:54pm
Cymruambyth
Wales
Ah see....you have the nice dial...I have the old manual shifter.....peasant spec Laughing Steve.
Post #535488 Fri Sep 15 2017 5:55pm
Cymruambyth
Wales
Ooh...Telford....handy...cheers matey Thumbs Up Steve.
Post #535490 Fri Sep 15 2017 6:00pm
DrRob
PM off here and he'll soon reply
He can also do a host of other useful stuff whilst he's with you including a gearbox flush which is recommended Thumbs Up Visitor from fullfatrr.com
Post #535491 Fri Sep 15 2017 6:02pm
geoffsnook
Get it adjusted as quick as before it goes into meltdown as a new unit is north of £400 plus fitting i use my handbrake every now and again if its on a slope but not all the time Thumbs Up
Post #535492 Fri Sep 15 2017 6:03pm
DrRob
Wot he said - use the bible to adjust it in the short term then get Bodsy over to do a full overhaul etc.
He also fits remote kits for the fuel burning heater for winter, software updates and other great things Thumbs Up Visitor from fullfatrr.com
Post #535493 Fri Sep 15 2017 6:21pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
My 13MY did not automatically apply the EPB so I used my iiDTool to set it to do this, which it now does unless I manually select P first. From memory it is a feature for manual gearboxes (didn't think any RRS's were manual, possibly Discoveries?) as there would not be any gearbox park function. But I enabled it as I prefer to know the handbrake is on (also stops it seizing through lack of use). 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #535495 Fri Sep 15 2017 6:42pm
Page 1 of 3 123>
