![]() | Home > Technical > Electronic Park Brake issue. |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
Don't no if this will help but hope so, me and the wife went away on holiday for two weeks came back to the long stay car park started the car pressed release on the handbrake and reversed only to hear a crunch and grinding noise. Drove it home booked it into the local LR dealership mechanic said they had ceased on in the two weeks away and advised us to leave the hand brake off if it was to be left for any length of time. Then came there bill £600 |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Ah right. I don`t think it`s siezed as it worked just now. I had similar on my Scooby when I`d washed the car and then it froze over night.....shredded the ABS rings |
How can you leave the handbrake off, it comes on automatically when ignition is turned off and you leave it in Park, which if you don't put it into Park, it also returns whatever position it was in back to Park? |
Mine doesn`t do that nor my mates 3.6 HSE. Steve. |
Sorry, Does it not have electronic hand brake system? Just checked my handbook and it also states in there this is a normal procedure. John
Yes mate, it`s electronic. Maybe that`s a feature on newer ones.....mine is 2006. Steve. |
Info from facelift manual MY12 and actually seen when getting back into car, and the gear change dial you actually see move to Park. Not doubting you at all, it could be a later introduction, if so I'm sorry not knowing about the earlier models. |
Sounds like it needs adjusting.
Ah see....you have the nice dial...I have the old manual shifter.....peasant spec |
Ooh...Telford....handy...cheers matey ![]() |
PM off here and he'll soon reply
Get it adjusted as quick as before it goes into meltdown as a new unit is north of £400 plus fitting i use my handbrake every now and again if its on a slope but not all the time |
Wot he said - use the bible to adjust it in the short term then get Bodsy over to do a full overhaul etc.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
My 13MY did not automatically apply the EPB so I used my iiDTool to set it to do this, which it now does unless I manually select P first. From memory it is a feature for manual gearboxes (didn't think any RRS's were manual, possibly Discoveries?) as there would not be any gearbox park function. But I enabled it as I prefer to know the handbrake is on (also stops it seizing through lack of use). 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
