![]() | Home > Maintenance & Modifications > Battery drain |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Brief update, checked voltage this morning and it's 11V across the terminals... 2006 RRS S/C CONSTANTLY under modification...
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Alternator?
Hi Andy,
Common drain is the rear tailgate handle switch. Bodsys Brake Bible
Cheers Bodsy,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5043 ![]() ![]() ![]() |
That's the same rated battery my 5.0L S/C had from new, the petrol one's seem to be lower rated than the diesel spec. ones. I actually replaced mine with a Varta AGM Stop/Start battery I think it was type G14 whatever that translates to in rating but is higher than original and never been any problem, when get a few minutes will have a look under bonnet and check rating. Look's Like 95Ah 850A. UK code 019 AGM
Looks like an original battery get it changed and see if you can get a 95 ah one for a bit more power |
Cheers Col & Geoff |
Does sound like a new battery would be a good idea.
Thanks for all the comments.
Well thanks for all the help and advise |
Never ever done that.That sounds very dodgy to me |
Geoff,
Do not think they will but cranking amps will always make starting easy |
