Home > General > Car alarm keeps going off |
common problem with the bonnet catch sensor search on here for it not sure if it can be adjusted r needs a new one if you cant find it here search on disco3 |
Sun Aug 06 2017 7:48am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
As above, try a new bonnet catch sensor. Search on Disco3 site will come up with some helpful stuff Visitor from fullfatrr.com
Sun Aug 06 2017 7:57am |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 245 |
Cheers for the link. The car did unlock/lock normally on previous occasions but last night it just made a double peep noise and didn't lock again. It hadn't shown the bonnet unlocked warning previously either!
Sun Aug 06 2017 8:15am |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 |
Mine was in back with LR last week for exactly the same fault, they replaced the sensor. |
Sun Aug 06 2017 8:34am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Yes normally is the bonnet sensor tah cause the problem, you can
