Home > General > Car alarm keeps going off
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
As the title says and it's really annoying. All times of day and night; however, last night it went off and finally indicated that the bonnet was open! With opening and forcefully closing the bonnet, I'm hoping that this issue has been solved.
Anyone else had a similar problem?
Post #532124 Sun Aug 06 2017 8:44am
geoffsnook
common problem with the bonnet catch sensor search on here for it not sure if it can be adjusted r needs a new one if you cant find it here search on disco3 Thumbs Up
Post #532125 Sun Aug 06 2017 8:48am
DrRob
As above, try a new bonnet catch sensor. Search on Disco3 site will come up with some helpful stuff Thumbs Up Visitor from fullfatrr.com
Post #532126 Sun Aug 06 2017 8:57am
Salisburylander
Cheers for the link. The car did unlock/lock normally on previous occasions but last night it just made a double peep noise and didn't lock again. It hadn't shown the bonnet unlocked warning previously either!
There have been several times where the right hand bonnet catch came undone when driving so it might be something to do with that too.
Post #532127 Sun Aug 06 2017 9:15am
wings21660
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Mine was in back with LR last week for exactly the same fault, they replaced the sensor. Thumbs Up
Post #532131 Sun Aug 06 2017 9:34am
flydive
Yes normally is the bonnet sensor tah cause the problem, you can
-Try to clean it and adjust it, might work.
- replace it, I think it doesn't cost much.
- remove it and bridge the wires. '08 RRS TDV8
Post #532132 Sun Aug 06 2017 9:34am
