Home > Technical > Reduced performance message |
Did you get a warning light did it on mine changed the aux water pump and everything good its quite well known on here search for aux water pump |
Tue Aug 01 2017 7:38pm |
ssandps Member Since: 22 Nov 2016 Location: Staines Posts: 23 |
Did not get any warning lights , just the message ... is the auxiliary pump anything to do with the supercharger? |
Tue Aug 01 2017 7:41pm |
sometimes it does not and yes i believe yours may fall in the vin range of the supercharger being wired backwards |
Tue Aug 01 2017 8:03pm |
Sorry , what does that mean , is the pump running backwards ? So what do I need to do ? |
Tue Aug 01 2017 8:08pm |
Yes it Will need a new pump and the wires need to be changed search on here for it or is quite common the pump can be found on eBay try and get a Bosch one bought mine for £110 |
Tue Aug 01 2017 8:48pm |
OK will do
Tue Aug 01 2017 8:50pm |
You don't need to buy a new pump, it's the wiring loom that is wired incorrectly not the pump.. you either need to change the pins on the connector, cut and re-wire or brake a tab off the pump then the connector can be reversed.
Wed Aug 02 2017 9:16am |
