Home > Technical > Reduced performance message
ssandps
United Kingdom 2006 Range Rover Sport Supercharged Sumatra Black
Hi , I have rrs supercharged 06 plate , while driving yesterday doing about 75mph a message pinged up saying reduced engine performance , then the speed dropped to approx 50mph . There were no warning lights , also the speed would increase but very slowly . I pulled over turned the engine off for about 30 seconds then restarted it . It the ran as normal with normal performance .. has anybody any idea's what could cause this , it is poss the 2nd time it has happened the wife was driving last time ....
Thanks
Post #531872 Tue Aug 01 2017 7:24pm
geoffsnook
Did you get a warning light did it on mine changed the aux water pump and everything good its quite well known on here search for aux water pump Thumbs Up
Post #531873 Tue Aug 01 2017 7:38pm
ssandps
Did not get any warning lights , just the message ... is the auxiliary pump anything to do with the supercharger?
Post #531874 Tue Aug 01 2017 7:41pm
geoffsnook
sometimes it does not and yes i believe yours may fall in the vin range of the supercharger being wired backwards Thumbs Up
Post #531875 Tue Aug 01 2017 8:03pm
ssandps
Sorry , what does that mean , is the pump running backwards ? So what do I need to do ?
Post #531876 Tue Aug 01 2017 8:08pm
geoffsnook
Yes it Will need a new pump and the wires need to be changed search on here for it or is quite common the pump can be found on eBay try and get a Bosch one bought mine for £110 Thumbs Up
Post #531882 Tue Aug 01 2017 8:48pm
ssandps
OK will do
Thanks for the advise
Post #531883 Tue Aug 01 2017 8:50pm
Socast
You don't need to buy a new pump, it's the wiring loom that is wired incorrectly not the pump.. you either need to change the pins on the connector, cut and re-wire or brake a tab off the pump then the connector can be reversed.
So Geoff, I would take another look at yours as you've not actually fixed the problem.
Post #531902 Wed Aug 02 2017 9:16am
