Home > Technical > Revisited 2007 "7A" TDV6 EGR BLANKING. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Done quite literally, hundreds of EGR blanks on 07/08/09 models, and never had an issue |
Thu Jun 22 2017 7:21pm |
Same here, as long as it has the right software patch applied, you won't get EML appearing for an egr fault.
Thu Jun 22 2017 9:10pm |
Oh and you don't have to have working egrs to blank them. The only people that tell you that you do are the cheap generic remappers that can't map them out properly...... Bodsys Brake Bible
Thu Jun 22 2017 9:11pm |
Terrye Member Since: 20 Jun 2017 Location: Wales Posts: 9 |
Thanks for the reply gents.
Fri Jun 23 2017 6:53pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
My RRS is 2005 so did not need the software patch. I bought the kit from ebay for about £15 and fitted it myself. It was a bit fiddly as the egrs are situated fairly low in the engine bay but a pretty easy job really.
Fri Jun 23 2017 7:33pm |
Cheers mate.
Fri Jun 23 2017 8:32pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
I have an O7MY and my egrs failed back in 2011 - before emulators. I bought two new EGRs and a BAS blanking kit - and remapped the ECU with the BAS version. As part of that process and before fitting the new EGRs I participated in an early remapping trial by BAS that included taking the EGrs out of the system - an early emulator.
Sat Jun 24 2017 4:31am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Very easy solution with no hassle = Bodsy is mobile and can do it all for you and you will be assured it's done properly. Job done Visitor from fullfatrr.com
Sat Jun 24 2017 7:38am |
Cheers Dr rob.
Sat Jun 24 2017 10:41am |
Sat Jun 24 2017 12:34pm |
Spotted and emailed. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Mon Jun 26 2017 4:55pm |
Many thanks to bodsy who came down to my house the very next day.
Fri Jun 30 2017 9:58pm |
No problem, Great to meet you and have a chinwag. Bodsys Brake Bible
Sun Jul 02 2017 8:42pm |
