![]() | Home > Tips & Tricks > Peanut butter. Toothpaste. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Peanut butter (smooth) for cleaning rubber trims. Toothpaste for cleaning oxidised headlamps. Both work brilliantly. Wish I'd discovered both before spending £££££££s on car products. Barrie.
Hi Socast. Thanks for your post. Fortunately this has not happened - whether or not it's because I only used a little or it was the non-abrasive/non-crystallsied paste I don't know but yes, there is probably a risk of damaging the lacquer. I can only speak from experience.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It will have been abrasive otherwise it wouldn't have refreshed your headlights. It would be an idea to get them re-laquered as they will bleach pretty quickly. |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Can't you just clear coat them yourself??? The head lamps are really easy to remove and a can of clear-coat costs 20 bucks CDN... 3 coats and you're off to the races |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
There is also a youtube video with someone using WD40 on cloudy headlights |
