Home > Tips & Tricks > Peanut butter. Toothpaste.
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Peanut butter (smooth) for cleaning rubber trims. Toothpaste for cleaning oxidised headlamps. Both work brilliantly. Wish I'd discovered both before spending £££££££s on car products. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #528137 Wed Jun 14 2017 10:07am
Socast
You realise that the headlamps have a laquer on them right ?
The toothpaste will take that off and then the plastic underneath will become sunbleached and do that horrible cracking thing that they do.
Have your local body shop polish them and add a new clear coat.
Post #530093 Tue Jul 11 2017 9:46am
BJH1959
Hi Socast. Thanks for your post. Fortunately this has not happened - whether or not it's because I only used a little or it was the non-abrasive/non-crystallsied paste I don't know but yes, there is probably a risk of damaging the lacquer. I can only speak from experience.
The lights are still looking good to date. They will get a polish and clear coat when the car gets its winter service. Barrie.
Post #530095 Tue Jul 11 2017 10:15am
Socast
It will have been abrasive otherwise it wouldn't have refreshed your headlights. It would be an idea to get them re-laquered as they will bleach pretty quickly.
Post #530100 Tue Jul 11 2017 10:30am
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Can't you just clear coat them yourself??? The head lamps are really easy to remove and a can of clear-coat costs 20 bucks CDN... 3 coats and you're off to the races
Post #567467 Mon Oct 22 2018 5:35pm
Lindab
There is also a youtube video with someone using WD40 on cloudy headlights
Post #567469 Mon Oct 22 2018 5:48pm
