Home > Maintenance & Modifications > Lowering ??
SMA_9524
Northern Ireland 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Lowering ??
2013 autobiography Range Rover sport
I'm looking to lower the jeep to sit at a nice driving height, does lowering links work?
I want the suspension to act as normal with just a lower driving height and want the access mode to work as normal
Is this possible in a 2013 autobiography with using lowering links?
Help and advice appreciated
Post #527938 Sun Jun 11 2017 1:55pm
Hi, welcome to the forum.
First point - it's not a "jeep"! Jeeps are a specific make of vehicle and not nearly as nice as Land Rovers. Whistle Keep calling it a "jeep" and we'll start ignoring you! Rolling with laughter
Second point, you can lower the vehicle using links but you would need adjustable ones if you want to have access height available. You would need to experiment how far you can lower it and still get access height to work. The problem is that if you lower it too much and then use access height, the vehicle thinks the suspension has bottomed out and raises to off road height. This is to prevent grounding of the underside of obstacles.
An alternative is to buy an IIDTool but I'm guessing you're not wanting to spend £300+ to do this.
Lowering the vehicle will result in a slightly firmer, springy ride which is somewhat at odds with the Range Rover ethos. But hey, it's your choice. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #527939 Sun Jun 11 2017 2:05pm
DrRob
Leave it as it was designed or expect issues in the future Thumbs Up
YHBW Whistle Visitor from fullfatrr.com
Post #527944 Sun Jun 11 2017 3:43pm
Tyrefitter
Why would anyone want to lower a 4x4 especially a RRS...do you want it to look like this Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #527945 Sun Jun 11 2017 3:45pm
SMA_9524
Ok firstly when I mentioned lowering , at normal driving height I think it is very high when running 22" alloys, I have heard about these links but also heard you loose access mode, I just want to lower the driving height slightly and still be able to use the access mode. By doing this I know all about how the suspension wil feel spongy etc but I wouldn't be going terribly low
Post #527948 Sun Jun 11 2017 6:22pm
SteveNorman
I would recommend iid to alter just the standard height.
Be aware that as you lower the height, the camber will become more negative (tipping in at the top) which then causes more toe out (scuffing the tyres on the inside). It also affects handling.
A small reduction in height makes a big difference to the above.
So after you have it where you want it, get 4 wheel alignment done.
Regards
Steve
Post #527950 Sun Jun 11 2017 6:30pm
SMA_9524
This IID tool wer do u go about getting one of these and how are they installed or do u need a computer to set it up ?
Post #527955 Sun Jun 11 2017 6:51pm
you usually use a smart phone to connect to the IID BT (£400) via bluetooth.
Maybe I should lower mine as it's on 22". I only realised how much taller than normal it is when I parked next to another RRS last weekend Shocked
No wonder I am getting board of climbing in and out Rolling Eyes
Post #527956 Sun Jun 11 2017 7:14pm
I doubt being on 22 inch rims makes a huge difference to the height. I run 255/55/19 which is overall taller than the 285/35/22 would be and mine isn't "in the air". The arches are filled much more effectively than the rubber band rubber manages and it can go near kerbs without fear of scuffs to the wheels. Not that I worry about scuffs to the wheels, however, but you know what I mean. 2012 SDV6 - it's missing a couple of cylinders
Post #527957 Sun Jun 11 2017 7:46pm
SMA_9524
Look if u can't help go and write somewer else Thumbs Up
Post #527958 Sun Jun 11 2017 7:48pm
SMA_9524
No I know the size wouldn't matter but my point is I think it is very high at driving height compared to other 4x4s and I'm just wondering what is the best way about lowering the driving height slightly
Post #527959 Sun Jun 11 2017 7:50pm
You plug it in to the OBD port. You need to do an initial set up / registration but the instructions are easy to follow.
IID not only allows you to play with heights, it allows you to look at (and clear) fault codes, check live values of lots of parameters (useful for diagnosing issues).
Several online suppliers. 2012 SDV6 - it's missing a couple of cylinders
Post #527961 Sun Jun 11 2017 7:53pm
My comment was a reply to Andy K... Whistle
The reason it has a highish ride height is because, unlike every other maker's 4x4, this one can actually go off road. 2012 SDV6 - it's missing a couple of cylinders
Post #527962 Sun Jun 11 2017 7:54pm
Tyrefitter wrote:
Andy.
What sort of bastard does that to a FullFat? Shocked
They should be shot and then incinerated. Censored 2012 SDV6 - it's missing a couple of cylinders
Post #527963 Sun Jun 11 2017 7:57pm
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
wrong post!
Post #527964 Sun Jun 11 2017 7:57pm
