Home > Maintenance & Modifications > Lowering ?? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Hi, welcome to the forum.
Sun Jun 11 2017 2:05pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Leave it as it was designed or expect issues in the future
Sun Jun 11 2017 3:43pm |
Why would anyone want to lower a 4x4 especially a RRS...do you want it to look like this
Sun Jun 11 2017 3:45pm |
SMA_9524 Member Since: 11 Jun 2017 Location: Co.antrim Posts: 5 |
Ok firstly when I mentioned lowering , at normal driving height I think it is very high when running 22" alloys, I have heard about these links but also heard you loose access mode, I just want to lower the driving height slightly and still be able to use the access mode. By doing this I know all about how the suspension wil feel spongy etc but I wouldn't be going terribly low |
Sun Jun 11 2017 6:22pm |
SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 7 |
I would recommend iid to alter just the standard height.
Sun Jun 11 2017 6:30pm |
This IID tool wer do u go about getting one of these and how are they installed or do u need a computer to set it up ? |
Sun Jun 11 2017 6:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
you usually use a smart phone to connect to the IID BT (£400) via bluetooth.
Sun Jun 11 2017 7:14pm |
I doubt being on 22 inch rims makes a huge difference to the height. I run 255/55/19 which is overall taller than the 285/35/22 would be and mine isn't "in the air". The arches are filled much more effectively than the rubber band rubber manages and it can go near kerbs without fear of scuffs to the wheels. Not that I worry about scuffs to the wheels, however, but you know what I mean. 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 11 2017 7:46pm |
Look if u can't help go and write somewer else |
Sun Jun 11 2017 7:48pm |
No I know the size wouldn't matter but my point is I think it is very high at driving height compared to other 4x4s and I'm just wondering what is the best way about lowering the driving height slightly |
Sun Jun 11 2017 7:50pm |
You plug it in to the OBD port. You need to do an initial set up / registration but the instructions are easy to follow. IID not only allows you to play with heights, it allows you to look at (and clear) fault codes, check live values of lots of parameters (useful for diagnosing issues). Several online suppliers. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Jun 11 2017 7:53pm |
My comment was a reply to Andy K... The reason it has a highish ride height is because, unlike every other maker's 4x4, this one can actually go off road. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Jun 11 2017 7:54pm |
What sort of bastard does that to a FullFat? They should be shot and then incinerated. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Jun 11 2017 7:57pm |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 |
wrong post! |
