Home > Faults & Fixes > power to sat nav and audio
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
Any ideas guys
The battery was disconnected for some work to be done, , now the sat nav screen and the audio screen are dead.
TIH
Post #526398 Fri May 19 2017 6:57pm
Eaters
Don't go ahead until someone with more knowledge comes along here but is this a case for disconnecting both battery leads and shorting them out for 20 seconds or so (hard reset?) and then reconnecting .??
Or has a fuse blown? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #526409 Fri May 19 2017 10:21pm
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Will the engine start and run? - this can be a sign of a low charged battery, how long was it disconnected for?- hours, days, weeks?
If the engine starts leave it running for 5 mins or so and when the battery is charged sufficient it may come back, if so put a charger on your battery for 24 hours.
Post #526414 Sat May 20 2017 5:31am
rigpig100
Thanks guys,
every thing else in the car works ok, battery was off for a couple of days .
cant seem to find which fuse to check as I lost the manual,
TIA
Post #526419 Sat May 20 2017 6:51am
rigpig100
Hi Guys all sorted thanks.
It has fixed its self !!!
Cheers Bob
Post #526424 Sat May 20 2017 8:55am
TheWojtek
Yupp, the satnav and stereo won't come on before the battery reaches a certain voltage (it can be set in the hidden menu in the stereo). Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #526458 Sat May 20 2017 9:49pm
