Home > General > Some help and advice please
RogerStockport
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I have developed a rotational drone noise that gets faster as the car speeds up, and is less obvious at speed, in that it is hardly noticeable.
My car has done 128,000 miles mostly motorway work. I took the car to a local Land Rover garage (not main dealer), and they thought it was the handbrake binding on the rear disks, as they were corroded, so £600 later with all new rear disks, pads and handbrake kit, no difference to the drone.
The same garage took a sample of the oil from my front and rear diffs and the transfer box, both diffs were clear but the transfer box had a metalic sheen and dark cloudiness. They changed the oil, but they feel certain it's the transfer box.
I'm reluctant to go to the extra expense of replacing the transfer box without being certain, as I've read that the transfer box is a grating noise that gets louder with speed, rather than my symptom, which sounds more like a failed wheel bearing or hub.
Any guidance or advice greatly appreciated.
Roger
Post #523550 Thu Apr 13 2017 2:17pm
DrRob
Did they check wheel bearings...? Visitor from fullfatrr.com
Post #523561 Thu Apr 13 2017 4:17pm
Russben
The independent thought it was the rear brakes.....but it wasn't, and now they're certain it's the transfer box. How certain were they when they thought it was the brakes? I'm in the shed, I'll be back in the real world in a minute.
Post #523628 Fri Apr 14 2017 3:57pm
Eaters
Yes, but did they check the wheel bearings? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #523634 Fri Apr 14 2017 5:17pm
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Hi mate I had the same issue exactly what you have said I swapped discs pads and did front hubs wheel bearings
Also swapped rear bearing
Gave up the wheel and same noise was still there
It was in fact transfer box £870 rebuild
Post #523638 Fri Apr 14 2017 6:38pm
Mr Crabtree
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Take it to Andy at A1 4x4 Bury .... oh and mention here Thumbs Up he might start a discount for RRS members ...Andy? Working with Virgin Trains and band of Brothers/Sisters to do something special for our injured servicemen and women
Post #523663 Sat Apr 15 2017 6:06am
