![]() | Home > Technical > Noisy Window Wipers! |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Take it into Off Topic, that's what it's there for ![]() |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
This is exactly what I am experiencing..... they are awfull .
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
Do you think it is a bad rubber compound in the blades? Mine have been fine, then all of a sudden they are terrible and probably the worst I've ever had in any car (not quite as bad as my 1973 Mini - the wipers used to lift off the screen at above 50mph!). Matt
I've just spoken to my dealer about the wipers to see if there is an updated blade available or it is a known problem. Of course I got the normal responce - bring it in and we'll look at it, not willing to look into blade options or if this is a known issue first - we must have the car!
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
The only issue I have with the wipers is the fact that when you wash the car they don't lift off the screen like in any other car, they only lift about 2 inches. Strange. Unless that is to stop them lifting off the screen at speed, seemed odd that they didn't try and hide the wipers in some fashion so that they don't stick out so much as a 'wind stoppers'. Can't be good for aerodynamics or drag coefficient. L319 D4 HSE
IamNotMarkWalker Member Since: 11 Oct 2005 Location: No Fixed Abode Posts: 6 ![]() ![]() |
3 hours, lol, you'll be lucky,
Don't the wipers lift becuase the arms hit the bonnet edge? Matt
Great..That's interesting stuff...
Neither! That's an off-line topic, which I took offline with Kam. L319 D4 HSE
OK
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Move to Australia MDP......no need for wipers over here. We just went onto Stage 3 water restrictions in Melbourne!!! RRS TDV6 Bluetooth, VR, Roof ![]() |
woody Member Since: 07 Jun 2006 Location: surrey Posts: 41 ![]() ![]() |
I am suffering from the same irritating noise (from the wipers!) I no longer use the auto function, i have to wait til the screen is soaked in rain before i use them otherwise they just drag across the screen.
MD, have you tried clearing the windscreen with white spirit? You may find that if you have been driving a lot on wet motorways you have picked up residue from a surface that has been dry for a long time and then once it has rained the deposited oil and rubber has been sprayed onto you screen and dried. Careful application on a rag should clear all the deposits off, but be careful not to get any white spirits on your paintwork and if you clean your wiper blades with it as well make sure that you rinse them well with hot soapy water afterwards. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Peter Member Since: 28 Feb 2006 Location: Maidenhead Posts: 175 ![]() ![]() ![]() |
My RRS was nine months old when it went back to Stratstone Woburn Green (Berkshire) for a list of about 20 jobs to be done.
