Home > Technical > Spark Plugs & TH leads
delta351
Hi all, I am after new spark plugs and HT leads for my 2006 RRS Supercharged
Could any one tell me the best ones to buy please.
I have a very slight miss fire on tick over. Very Happy 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521575 Tue Mar 21 2017 8:24pm
Didn't think they had HT leads? Coils straight onto plugs.
jag engines are quite fussy, so probably need to stick to NGK.
See ebay, and you should get some change out of £100 Big Cry
Could be a faulty coil. Any fault codes reported for misfire on Bank x ?
Post #521576 Tue Mar 21 2017 8:38pm
delta351
Plugs
thanks Andy I am a Censored head don't know why I typed HT leads Rolling with laughter
just standard NGK's or NGK IRIDIUM ? 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521578 Tue Mar 21 2017 8:41pm
Bobby
2006 Supercharged Engine Ignition
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #521587 Wed Mar 22 2017 2:56am
Socast
90% certain the slight miss fire (more of an engine stumble, can't be heard but you feel the shudder through the steering wheel etc?) will be the injectors need cleaning.
Next job on my list. Thumbs Up
EDIT; Oh you need the Iridium plugs (they're good for 100k miles before they need changing.. usually!)
Post #521601 Wed Mar 22 2017 9:17am
geoffsnook
I to have this stumble is a tin of injector cleaner enough or does it take more as it's only on tick over everything else is ok Thumbs Up
Post #521609 Wed Mar 22 2017 10:39am
Socast
It's worth trying a can or two of BG44 to see if that helps, getting the injectors out is quite a big job.
Post #521612 Wed Mar 22 2017 11:07am
I've been told to increase the plug gap on my Jag from 1.0 to 1.3mm (probably go for somewhere in between) to make it idle better.
Post #521620 Wed Mar 22 2017 12:08pm
Socast
Have you changed the plug gaps on your Jag ?
I'm guessing this will be a cheaper and quicker fix than cleaning the injectors. That being said doing both can only be a good thing.
I'll dig out the feeler gauges this weekend and see if it makes a difference. Thanks for the tip Very Happy
Post #521624 Wed Mar 22 2017 12:31pm
Not yet. Hopefully I'm gonna try and measure the gap at the weekend, but won't drive for a while
Post #521675 Wed Mar 22 2017 5:29pm
From what I can make out, this only applies to very early jags, (long before the RRS)
and Iridium plugs seam to get set to 1.0mm
Post #521943 Sun Mar 26 2017 1:29pm
Socast
I had a look after you mentioned it and as you say the default plug gap on the 4.2SC is between 0.9 and 1.0 mm.
I've not had chance yet but I was going to set mine to 1.2, but as I said, I think this is a temporary fix rather than cleaning the injectors.
Post #522168 Tue Mar 28 2017 6:53pm
delta351
BG44
I have ordered a can of BG44 let se if t makes a differents! 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #525516 Sun May 07 2017 3:58pm
my jag Iridium's were at 0.9mm so moved them to 1.1mm
Post #525517 Sun May 07 2017 4:35pm
delta351
any change? 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #525518 Sun May 07 2017 4:36pm
