![]() | Home > Technical > Spark Plugs & TH leads |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
Hi all, I am after new spark plugs and HT leads for my 2006 RRS Supercharged
thanks Andy I am a |
2006 Supercharged Engine Ignition
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
90% certain the slight miss fire (more of an engine stumble, can't be heard but you feel the shudder through the steering wheel etc?) will be the injectors need cleaning.
I to have this stumble is a tin of injector cleaner enough or does it take more as it's only on tick over everything else is ok |
It's worth trying a can or two of BG44 to see if that helps, getting the injectors out is quite a big job. |
I've been told to increase the plug gap on my Jag from 1.0 to 1.3mm (probably go for somewhere in between) to make it idle better. |
Have you changed the plug gaps on your Jag ?
Not yet. Hopefully I'm gonna try and measure the gap at the weekend, but won't drive for a while |
From what I can make out, this only applies to very early jags, (long before the RRS) and Iridium plugs seam to get set to 1.0mm |
I had a look after you mentioned it and as you say the default plug gap on the 4.2SC is between 0.9 and 1.0 mm.
I have ordered a can of BG44 let se if t makes a differents! 2006 RR Sport Supercharged Love this car
my jag Iridium's were at 0.9mm so moved them to 1.1mm |
any change? 2006 RR Sport Supercharged Love this car
