Home > Technical > passenger carpet still wet
steve.rrs
pasenger carpet still wet and not coming from the sunroof, any ideas please
steve
Post #521318 Sat Mar 18 2017 6:20pm
SAS32
I've read of poor sealing of the plastic scuttle below the windscreen, especially if it has been replaced recently.
Blocked A/C drains.
This is also worth a read: http://www.rrsport.co.uk/gallery/albums/us...illar2.pdf
Post #521382 Mon Mar 20 2017 12:01am
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
You could also have an issue like i did. Sunroof entrances to the drainage pipes was blown clean with compressed air, but in the end the drainage pipe on what is your drivers side wasn't draining out of the car, the pipe had dried and broken and was draining into the footwell.
a 1 hour job and complete pipe was replaced. no more wet carpets. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #521383 Mon Mar 20 2017 6:45am
Socast
Mine was leaking from the A Pillar, clips can be ordered off ebay for a fraction of the price the dealership sells them for.
Post #521411 Mon Mar 20 2017 11:54am
Socast
Post #521412 Mon Mar 20 2017 11:55am
Black Bess
I had this problem with my 2005 Sport. First I cleared the sunroof drains, which did have a bit of muck in them, (cleared by blowing both ways with an air line.) but the problem persisted.
Then I removed the cover at the base of the windscreen (it clips in with about 6 plastic trim clips). If water defeats the rubber seal on the windscreen glass, it can run under the cover and drain directly into the heater intake (yes, really). So I made a plastic shield to deflect any water that went that way. Replace with new trim clips.
Finally, I took the A pillar cover off. It is also secured with the same plastic clips, with an O ring seal on them, plus one screw at the bottom. Water was entering via the trim clip holes, especially the peg at the bottom that is sealed with foam rubber (!). I refitted with new clips and a good dollop of silicone sealer across each hole and Viola! The leaking stopped.
The floor under the carpet has a channel with a wring loom going through it. I lifted the carpet a bit and blew the water out with an airline and dried the foam underlay with an electric blower heater (greenhouse heater). After that, all was well.
Whilst it was full of water, my central locking stopped working. Once dry, it all worked again.
Adam..
Post #521551 Tue Mar 21 2017 1:58pm
steve.rrs
thanks, i will look at all them areas over the weekend, i also had the central locking stop when the carpet was soaking wet
Post #521769 Thu Mar 23 2017 8:29pm
nuke
Romania 2006 Range Rover Sport TDV6 HSE Java Black
hello mates,
my rrs ''06 has no sunroof ,
the passenger side carpet gets soaking wet only when i use AC ,
found nothing on forum related on how to fix this issue ,
i apreciate any thoughts / advices
Post #565811 Mon Sep 24 2018 3:14pm
Unblock the AC drains. They exit above the gearbox
But I believe you need to unblock it inside
Post #565817 Mon Sep 24 2018 5:17pm
nuke
Andy K,
apreciate your input on my issue,
can you please be more specific ?
can it be done home ?
or do i need to go to visit a LR service ?
Post #565830 Tue Sep 25 2018 8:05am
yes you can do at home.
try seatching the site for pictures of
a/c drain
air con drain
wet carpet
Post #565834 Tue Sep 25 2018 11:08am
