![]() | Home > Technical > FM Antenna Fault and no DAB reception |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
Make sure the connector hasn't come off the rear side glass, they just pop on. It uses a little signal booster up in the headlining I honestly can't remember which one is the DAB, but check the connector on the side glass first. Life's too short to drive boring cars !
nplatts Member Since: 16 Mar 2017 Location: Bingley Posts: 3 ![]() ![]() ![]() |
Thanks, tried those popped them off and refit but no change, also done the reset process with the battery. Do
Depending on the spec of the car there are a few modules in the headlining, I think the fm is on the rear screen as well as the sides. Dab and tv I think are on the sides. See how many connectors you have on the rear and side glass. I have a few amplifier modules at home, they are colour coded. Also worth checking the amplifiers are being powered up and have a good ground. Life's too short to drive boring cars !
Thanks, there are three connectors, no TV on the car, ill have a look at the modules this weekend. |
Lsmcars Member Since: 28 Oct 2020 Location: Berkshire Posts: 1 ![]() ![]() |
Hello
